주요 콘텐츠로 건너뛰기
Dell Inspirion 15z-5523 Hard Disk Drive Replacement
필요한 것
  1. Dell Inspirion 15z-5523 Hard Disk Drive Replacement, Hard Disk Drive (HDD): 1 단계, 이미지 1개 중 1개
    • Pop out the rubber pieces and unscrew the 7 screws on the bottom of the computer.
    • Open the RAM door in the center remove the hidden screw labeled "KB" just above the RAM sticks.
  2. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Using a nylon spudger, push the retaining clips away from the keyboard - there are five along the top row, and two on each side. You can carefully pull the keyboard away from each clip when it's released. The bottom edge of the keyboard will just pull away.
  3. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 3 단계, 이미지 2개 중 1개 Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 3 단계, 이미지 2개 중 2개
    • There are two ribbon cables securing the keyboard - data and backlight power. Each ribbon connector must be released by flipping the black retainer up with a fingernail or nylon Uspudger before pulling out the ribbon.
    • First flip up the black retainer on the smaller connector. Slide the cable up and out of the connector.
    • Secondly, flip the black connector up on the larger connector. Slide the cable straight out of the connector, parallel to the case.
    • Remove the keyboard from the case.
  4. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew the surface under the keyboard and remove top plate from the base.
  5. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Take the battery out by unscrewing the 5 screws and pulling straight off.
  6. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the hard drive.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Christian Chavez
회원 가입일: 01/23/18
729 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 15
전체 시간: 3,562
