소개
It is advised to proceed with caution when carrying out this procedure. Damage to the sensitive electronic components may occur.
필요한 것
Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
After removing the screws, remove the back cover using a plastic or metal spudger.
Unscrew the 3.7mm screw that attaches the solid state drive with the Phillips #0 screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
