소개
In this guide, we will be showing you how to remove and replace the Display Hinges.
필요한 것
Peel the tapes and remove the antenna cables from the routing guide on the hinge cover.
Remove the screws that secure the display hinges to the display back-cover and antenna assembly.
Align the screw holes on the NEW display hinges with the screw holes on the display back-cover and antenna assembly.
Replace the screws that secure the display hinges to the display back-cover and antenna assembly.
Route the antenna cables through the routing guide on the hinge cover and secure it in place.
