주요 콘텐츠로 건너뛰기
Dell Inspiron 11 3179 Display Hinges Replacement
필요한 것
  1. Dell Inspiron 11 3179 Display Hinges Replacement, Peeling the Tapes: 1 단계, 이미지 1/2 Dell Inspiron 11 3179 Display Hinges Replacement, Peeling the Tapes: 1 단계, 이미지 2/2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
    • Peel the tapes and remove the antenna cables from the routing guide on the hinge cover.
  2. Dell Inspiron 11 3179 Display Hinges Replacement, Remove the Screws: 2 단계, 이미지 1/1
    • Remove the screws that secure the display hinges to the display back-cover and antenna assembly.
  3. Dell Inspiron 11 3179 Display Hinges Replacement, Lifting the Display Hinges: 3 단계, 이미지 1/2 Dell Inspiron 11 3179 Display Hinges Replacement, Lifting the Display Hinges: 3 단계, 이미지 2/2
    • Lift the display hinges off the display back-cover and antenna assembly.
  4. Dell Inspiron 11 3179 Display Hinges Replacement, Aligning the Screw Holes: 4 단계, 이미지 1/1
    • Align the screw holes on the NEW display hinges with the screw holes on the display back-cover and antenna assembly.
  5. Dell Inspiron 11 3179 Display Hinges Replacement, Replace the Screws: 5 단계, 이미지 1/1
    • Replace the screws that secure the display hinges to the display back-cover and antenna assembly.
  6. Dell Inspiron 11 3179 Display Hinges Replacement, Routing the Antenna Cables: 6 단계, 이미지 1/1
    • Route the antenna cables through the routing guide on the hinge cover and secure it in place.
결론
Terrence15
회원 가입일: 12/18/17
79,121 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 190
