주요 콘텐츠로 건너뛰기
Dell Inspiron 11 i3147 Camera Replacement
필요한 것
  1. Dell Inspiron 11 i3147 Camera Replacement, Camera: 1 단계, 이미지 1/1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Camera Replacement: 2 단계, 이미지 1/1
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Camera Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Camera Replacement: 4 단계, 이미지 1/1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Camera Replacement: 5 단계, 이미지 1/1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Camera Replacement: 6 단계, 이미지 1/1
    • Lift the battery from the keyboard.
  7. Dell Inspiron 11 i3147 Camera Replacement: 7 단계, 이미지 1/1
    • Disconnect antenna cables.
  8. Dell Inspiron 11 i3147 Camera Replacement: 8 단계, 이미지 1/1
    • Remove 2 4mm PH0 screws that connect display cable bracket to the system board.
    • Lift display cable bracket off the system board.
  9. Dell Inspiron 11 i3147 Camera Replacement: 9 단계, 이미지 1/1
    • Use the pull tab to disconnect the display cable from the system board.
  10. Dell Inspiron 11 i3147 Camera Replacement: 10 단계, 이미지 1/1
    • Pull the windows button board cable from the system board.
  11. Dell Inspiron 11 i3147 Camera Replacement: 11 단계, 이미지 1/1
    • Remove the 2 5.6mm PH0 screws.
  12. Dell Inspiron 11 i3147 Camera Replacement: 12 단계, 이미지 1/1
    • Separate the screen and body of the computer.
  13. Dell Inspiron 11 i3147 Camera Replacement: 13 단계, 이미지 1/2 Dell Inspiron 11 i3147 Camera Replacement: 13 단계, 이미지 2/2
    • Use a plastic opening tool to take the display panel assembly off the display back cover and antenna assembly. Start from the top.
    • Place display panel face down on a flat surface
  14. Dell Inspiron 11 i3147 Camera Replacement: 15 단계, 이미지 1/1
    • Use a plastic opening tool to take the camera module off the display.
결론
Muhammad Erchid
회원 가입일: 10/09/18
1,051 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G6, Leahy Fall 2018 USF Tampa, Team S1-G6, Leahy Fall 2018 회원
USFT-LEAHY-F18S1G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 205
