주요 콘텐츠로 건너뛰기
Dell Inspiron 11-3147 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 11-3147 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 Dell Inspiron 11-3147 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Using the tab on the cables connector with your hand unplug the Hard Drive connection cable and remove it from the cable track on the battery.
  3. Dell Inspiron 11-3147 Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 Dell Inspiron 11-3147 Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 Dell Inspiron 11-3147 Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Pull back the sticker covering the first screw on the hard drive chaises.
    • Useing a Philips Head #0 screwdriver remove the three screws holding the drive in place.
  4. Dell Inspiron 11-3147 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the hard drive from the left side as depicted and remove.
  5. Dell Inspiron 11-3147 Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Unplug the adapter cable from the drive. No tool is required for this step.
  6. Dell Inspiron 11-3147 Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron 11-3147 Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron 11-3147 Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Using a Philips Head #1 Screwdriver remove the four screws holding the hard drive to the chassis.
    • Remove the drive from the chassis. Care that the drive does not fall out once all the screwshave been removed.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
William Brum
회원 가입일: 03/04/16
755 평판
안내서 5개를 작성함
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 UMass Dartmouth, Team 3-1, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S3G1
3 회원들
안내서 8개를 작성함
1가이드 댓글
I am a visual learner and with this guide, I had my hard drive changed and the backplate back on in less than 10 minutes. Thanks for the great guide.
Chris Hartfield - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 5,653
