주요 콘텐츠로 건너뛰기
Dell Inspiron 11-3147 RAM Replacement
필요한 것
  1. Dell Inspiron 11-3147 RAM Replacement, RAM: 1 단계, 이미지 1/2 Dell Inspiron 11-3147 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 RAM Replacement: 2 단계, 이미지 1/2 Dell Inspiron 11-3147 RAM Replacement: 2 단계, 이미지 2/2
    • Place finger nails on both of the little metal tabs that are located on shorter sides of the Ram board.
    • Pull tabs outward and away from the Ram card. This will detach the card from the computer and allow removal.
  3. Dell Inspiron 11-3147 RAM Replacement: 3 단계, 이미지 1/1
    • Carefully remove the RAM to ensure no other components get damaged.
    • Replace with a new RAM card the exact way it came out, with the the shiny metallic part of the card placed inside black insert as shown in the picture.
결론
다른 4명이 해당 안내서를 완성하였습니다.
William Brum
회원 가입일: 03/04/16
737 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 UMass Dartmouth, Team 3-1, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S3G1
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 24
전체 시간: 1,275
