주요 콘텐츠로 건너뛰기
Dell Inspiron 11-3147 Replace the Battery Replacement
필요한 것
  1. Dell Inspiron 11-3147 Replace the Battery Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 11-3147 Replace the Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 Replace the Battery Replacement: 2 단계, 이미지 1/1
    • The 4mm battery screws can be removed with a philips head #0 screw driver. All the screws that must be removed are shown in the attached pictures.
    • Place screws close by in a safe place such as a magnetic board or cup so they are ready and accounted for when you begin reassembly.
  3. Dell Inspiron 11-3147 Replace the Battery Replacement: 3 단계, 이미지 1/1
    • Once the screws have been removed the battery may then be simply removed by hand and replaced.
결론
다른 3명이 해당 안내서를 완성하였습니다.
William Brum
회원 가입일: 03/04/16
737 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 UMass Dartmouth, Team 3-1, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S3G1
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 18
전체 시간: 2,478
