소개
In this guide, you will be replacing the battery to your Dell Inspiron. When finished, you should understand how to dissemble the back panel and remove the battery.
필요한 것
After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
