소개
This guide will show you how to replace the USB Ports on your Dell Inspiron.
필요한 것
After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
Remove the two white power connectors on the bottom right of the motherboard by gently pulling on the tabs backward.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
