주요 콘텐츠로 건너뛰기
Dell Inspiron 11-3152 USB Port Replacement
필요한 것
  1. Dell Inspiron 11-3152 USB Port Replacement, Back Panel: 1 단계, 이미지 1/2 Dell Inspiron 11-3152 USB Port Replacement, Back Panel: 1 단계, 이미지 2/2
    • Flip the computer over.
  2. Dell Inspiron 11-3152 USB Port Replacement: 2 단계, 이미지 1/2 Dell Inspiron 11-3152 USB Port Replacement: 2 단계, 이미지 2/2
    • Remove all nine 5mm Phillips head screws from the back cover using #0 Phillips head.
  3. Dell Inspiron 11-3152 USB Port Replacement: 3 단계, 이미지 1/1
    • Gently use a spudger to pull the cover away from the rest of the laptop. The cover will come off after you use the tool on two or three sides.
  4. Dell Inspiron 11-3152 USB Port Replacement, Battery: 4 단계, 이미지 1/1
    • Make sure that the power is off.
    • After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
  5. Dell Inspiron 11-3152 USB Port Replacement: 5 단계, 이미지 1/2 Dell Inspiron 11-3152 USB Port Replacement: 5 단계, 이미지 2/2
    • Locate the battery at the bottom of the computer and remove the four 3mm screws with a Phillips #0 head that hold the battery down.
  6. Dell Inspiron 11-3152 USB Port Replacement: 6 단계, 이미지 1/1
    • Remove the Solid State Drive wire from the battery clip by detaching the wire.
    • This can be done by gently pulling the connector away from the battery clip.
  7. Dell Inspiron 11-3152 USB Port Replacement: 7 단계, 이미지 1/1
    • Remove the battery from the computer system by gently lifting it from the side.
  8. Dell Inspiron 11-3152 USB Port Replacement, USB Port: 8 단계, 이미지 1/1
    • Remove the two white power connectors on the bottom right of the motherboard by gently pulling on the tabs backward.
  9. Dell Inspiron 11-3152 USB Port Replacement: 9 단계, 이미지 1/2 Dell Inspiron 11-3152 USB Port Replacement: 9 단계, 이미지 2/2
    • Gently peel the tape on top of the power connectors that link the Solid State Drive to the motherboard.
    • Use spudger to lift and detach the power connector from the motherboard.
  10. Dell Inspiron 11-3152 USB Port Replacement: 10 단계, 이미지 1/2 Dell Inspiron 11-3152 USB Port Replacement: 10 단계, 이미지 2/2
    • Detach the purple ZIF connector and the white ribbon connector. This can be done by using a spudger to unlock the ZIF connector and pull the cable out.
    • Pull the ribbon cable that connects the keyboard to the motherboard away.
  11. Dell Inspiron 11-3152 USB Port Replacement: 11 단계, 이미지 1/2 Dell Inspiron 11-3152 USB Port Replacement: 11 단계, 이미지 2/2
    • Slide the ZIF cord connecting to the Solid State Drive towards itself to detach it from the motherboard.
  12. Dell Inspiron 11-3152 USB Port Replacement: 12 단계, 이미지 1/1
    • Unscrew the two 2mm screws on the silver brace in the top right of the laptop using a #0 Phillips head.
  13. Dell Inspiron 11-3152 USB Port Replacement: 13 단계, 이미지 1/2 Dell Inspiron 11-3152 USB Port Replacement: 13 단계, 이미지 2/2
    • Unscrew six 1mm screws holding down the motherboard using a #0 Phillips head.
  14. Dell Inspiron 11-3152 USB Port Replacement: 14 단계, 이미지 1/1
    • Lift up the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Duncan
회원 가입일: 03/10/16
481 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 4-6, Catania Spring 2016 UMass Dartmouth, Team 4-6, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 390
