소개
This guide will tell you how to replace your LCD screen. When working with screens, be careful about electrical discharges, and take steps to assure that the battery is disconnected for awhile before you follow this guide.
필요한 것
Use tweezers to pry and remove the center screw cover on the back cover.
Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
Between steps 9 and 10, the motherboard is removed and no description photos are provided for this. I undid the cable on the right hinge and then removed the hinges and screen with the motherboard in place, but the pictures definitely show it removed. Otherwise a very easy to follow process.
I agree with Philip’s comment re: the missing step between 9 and 10. I successfully followed these very clear instructions to repair my daughter’s Chromebook. Thank you!
