소개
This will show you how to remove & replace your motherboard. This would be a last step in attempting to repair your computer if you've attempted the other guides.
필요한 것
Use tweezers to pry and remove the center screw cover on the back cover.
Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
거의 끝나갑니다!
결론
다른 5명이 해당 안내서를 완성하였습니다.
