주요 콘텐츠로 건너뛰기
Dell Inspiron 11-3164 Battery Replacement
필요한 것
  1. Dell Inspiron 11-3164 Battery Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 11-3164 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Start by placing the laptop upside down to expose the first set of screws on the bottom of the laptop. Use your J1 Phillips head screwdriver bit to unscrew the 8 size 6 mm screws.
    • Remove the plastic cover to unveil the final screw holding the front and back frame together.
    • Remove this last screw of size 6mm with the J1 phillips head bit found in the approved iFixit toolkit.
  2. Dell Inspiron 11-3164 Battery Replacement: 2 단계, 이미지 1/2 Dell Inspiron 11-3164 Battery Replacement: 2 단계, 이미지 2/2
    • Using your metal pry tool, slowly pry the two halves apart by gently moving your tool around the laptop . Once all the way around the top and bottom half will separate.
    • When pulling the laptops apart be careful to hold them together at first due to the sensitive ribbon cable inside.
    • Use your metal pry tool again to push the ribbon holding clip up and remove the ribbon cable.
  3. Dell Inspiron 11-3164 Battery Replacement: 3 단계, 이미지 1/1
    • Use the J1 screw driver bit from earlier and unscrew the three size 4mm battery screws.
  4. Dell Inspiron 11-3164 Battery Replacement: 4 단계, 이미지 1/1
    • While using one hand to hold the laptop grab the power wire with the other hand and pull it out of it's port.
    • Carefully remove the battery pack from the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Kendziora
회원 가입일: 02/14/18
781 평판
안내서 5개 작성하였습니다
USF Tampa, Team S6-G4, Eyestone Spring 2018 USF Tampa, Team S6-G4, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 287
