주요 콘텐츠로 건너뛰기
Dell Inspiron 11-3164 Keyboard Replacement
필요한 것
  1. Dell Inspiron 11-3164 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 Dell Inspiron 11-3164 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Place laptop upside down to observe the first set of screws on the bottom cover. With the J1 Phillips head screwdriver bit, unscrew eight (8) size 60 mm screws.
    • With a metal spudger, remove the plastic cover to unveil the final screw.
    • With the J1 Phillips head bit, remove remaining 60 mm screw.
  2. Dell Inspiron 11-3164 Keyboard Replacement: 2 단계, 이미지 1/2 Dell Inspiron 11-3164 Keyboard Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • With a metal spudger, pry apart the bottom cover working around the edges.
    • While separating the halves of the bottom cover, carefully move the spudger up and down to avoid damaging the USB/Audio circuit board cable inside.
    • With tweezers, disconnect the USB/Audio circuit board cable.
    • Place the bottom cover off to the side.
  3. Dell Inspiron 11-3164 Keyboard Replacement: 3 단계, 이미지 1/1
    • With the J1 screwdriver bit, unscrew three (3) size 40 mm battery screws.
  4. Dell Inspiron 11-3164 Keyboard Replacement: 4 단계, 이미지 1/1
    • With tweezers, disconnect the battery cable.
    • Remove the battery pack.
  5. Dell Inspiron 11-3164 Keyboard Replacement: 5 단계, 이미지 1/3 Dell Inspiron 11-3164 Keyboard Replacement: 5 단계, 이미지 2/3 Dell Inspiron 11-3164 Keyboard Replacement: 5 단계, 이미지 3/3
    • Remove the M2 x 3mm bracket screw.
    • Remove the metal bracket.
    • With tweezers, detach the white and black antenna cables connected to the Wireless WLAN Card.
    • Remove the Wireless WLAN Card.
  6. Dell Inspiron 11-3164 Keyboard Replacement: 6 단계, 이미지 1/1
    • With tweezers, unplug the CMOS battery.
    • With tweezers, detach the CMOS battery.
  7. Dell Inspiron 11-3164 Keyboard Replacement: 7 단계, 이미지 1/2 Dell Inspiron 11-3164 Keyboard Replacement: 7 단계, 이미지 2/2
    • With tweezers, unplug the DC Jack cable.
    • With the Philips #0 Screwdriver, loosen the M2 x 3mm screw.
    • With tweezers, detach the DC Jack.
  8. Dell Inspiron 11-3164 Keyboard Replacement: 8 단계, 이미지 1/2 Dell Inspiron 11-3164 Keyboard Replacement: 8 단계, 이미지 2/2
    • With tweezers, disconnect the speaker cable.
    • With tweezers, detach the speaker.
  9. Dell Inspiron 11-3164 Keyboard Replacement: 9 단계, 이미지 1/2 Dell Inspiron 11-3164 Keyboard Replacement: 9 단계, 이미지 2/2
    • With the Philips #0 Screwdriver, unbolt the M2 x 3mm screw.
    • With tweezers, disconnect the display cable.
  10. Dell Inspiron 11-3164 Keyboard Replacement: 10 단계, 이미지 1/3 Dell Inspiron 11-3164 Keyboard Replacement: 10 단계, 이미지 2/3 Dell Inspiron 11-3164 Keyboard Replacement: 10 단계, 이미지 3/3
    • With the Philips #0 Screwdriver, unfasten the 2 - M2.5 x 5mm left and right hinge screws.
    • With the Philips #0 Screwdriver, unhinge the 2 - M2.5 x 5mm display cable bracket screw.
    • With tweezers, remove the LCD screen.
  11. Dell Inspiron 11-3164 Keyboard Replacement: 11 단계, 이미지 1/1
    • With the Philips #0 Screwdriver, loosen the 4 screws supporting the copper plate.
    • With tweezers, remove the copper plate.
  12. Dell Inspiron 11-3164 Keyboard Replacement: 12 단계, 이미지 1/2 Dell Inspiron 11-3164 Keyboard Replacement: 12 단계, 이미지 2/2
    • With tweezers, disconnect the keyboard cable.
    • With tweezers, disconnect the touchpad cable.
    • With the Philips #00 Screwdriver, loosen the four (4) M2 x 2mm screws.
    • Gently remove the mouse touchpad. The fixer is left with the palm-rest and keyboard assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Kendziora
회원 가입일: 02/14/18
781 평판
안내서 5개 작성하였습니다
USF Tampa, Team S6-G4, Eyestone Spring 2018 USF Tampa, Team S6-G4, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 11
전체 시간: 323
