주요 콘텐츠로 건너뛰기
Dell Inspiron 11-3164 Motherboard Replacement
필요한 것
  1. Dell Inspiron 11-3164 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Dell Inspiron 11-3164 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Start by placing the laptop upside down to expose the first set of screws on the bottom of the laptop. Use your J1 Phillips head screwdriver bit to unscrew the 8 size 60 mm screws.
    • Remove the plastic cover to unveil the final screw holding the front and back frame together.
    • Remove this last screw of size 60mm with the J1 phillips head bit found in the approved iFixit toolkit.
  2. Dell Inspiron 11-3164 Motherboard Replacement: 2 단계, 이미지 1/2 Dell Inspiron 11-3164 Motherboard Replacement: 2 단계, 이미지 2/2
    • Open the latches and disconnect the touch-pad cable and keyboard cable from the system board.
  3. Dell Inspiron 11-3164 Motherboard Replacement: 3 단계, 이미지 1/2 Dell Inspiron 11-3164 Motherboard Replacement: 3 단계, 이미지 2/2
    • Disconnect the battery cable from the system board.
    • Remove the screws that secure the battery to the palm rest and keyboard assembly by using the PH1 screw driver to unscrew the three size 40 mm battery screws.
    • There is no way that motherboard can be removed with battery pack still attached to the laptop.
  4. Dell Inspiron 11-3164 Motherboard Replacement: 4 단계, 이미지 1/1
    • Open the latch and disconnect the I/O-board cable from system board.
  5. Dell Inspiron 11-3164 Motherboard Replacement: 5 단계, 이미지 1/2 Dell Inspiron 11-3164 Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the 2mm screw that secures the motherboard and keyboard assembly.
  6. Dell Inspiron 11-3164 Motherboard Replacement: 6 단계, 이미지 1/2 Dell Inspiron 11-3164 Motherboard Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect the coin-cell battery cable from the system board.
    • To remove the cable, use a small pliers or Angled Precision Tweezers on the left and right ledges on the adapter.
    • Do not pull by the cord.
  7. Dell Inspiron 11-3164 Motherboard Replacement: 7 단계, 이미지 1/1
    • Removing the Wireless WLAN Card
    • Remove the M2 x 3mm bracket screw.
    • Remove the metal bracket.
    • With tweezers, detach the white and black antenna cables connected to the Wireless WLAN Card.
    • Remove the Wireless WLAN Card by slide the assembly out of motherboard wireless socket.
  8. Dell Inspiron 11-3164 Motherboard Replacement: 8 단계, 이미지 1/1
    • Disconnect the speaker cable from the system board.
  9. Dell Inspiron 11-3164 Motherboard Replacement: 9 단계, 이미지 1/2 Dell Inspiron 11-3164 Motherboard Replacement: 9 단계, 이미지 2/2
    • Remove the M2xL3 screw on display-cable guard to the system board.
    • Detach the cable beneath.
  10. Dell Inspiron 11-3164 Motherboard Replacement: 10 단계, 이미지 1/1
    • Disconnect the power-adapter port cable from the system board.
    • Use angle precision tweezers to put on the ledge alongside the adapter away from the motherboard socket.
    • Warning: to avoid damaging the cord, do not pull by the cable.
  11. Dell Inspiron 11-3164 Motherboard Replacement: 11 단계, 이미지 1/2 Dell Inspiron 11-3164 Motherboard Replacement: 11 단계, 이미지 2/2
    • Lift the mother board off the palm rest and keyboard assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Watis Ekthuvapranee
회원 가입일: 02/14/18
277 평판
안내서 1개 작성함
USF Tampa, Team S6-G4, Eyestone Spring 2018 USF Tampa, Team S6-G4, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 460
