소개
If your mousepad is working incorrectly, refer to this page's troubleshooting guide. This fix is only necessary after you have attempted the prerequisite fixes.
필요한 것
Place laptop upside down to observe the first set of screws on the bottom cover. With the J1 Phillips head screwdriver bit, unscrew eight (8) size 60 mm screws.
With a metal spudger, remove the plastic cover to unveil the final screw.
With the J1 Phillips head bit, remove remaining 60 mm screw.
다른 한 분이 해당 안내서를 완성하였습니다.
