주요 콘텐츠로 건너뛰기
Dell Inspiron 11-3164 Screen Replacement
필요한 것
  1. Dell Inspiron 11-3164 Screen Replacement, Screen: 1 단계, 이미지 1/2 Dell Inspiron 11-3164 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Lay the laptop flat with its bottom up exposing the screws holding it together. Unscrew these eight screws with a JIS #1 screwdriver and put them aside.
    • Use your screw driver to pry off the plastic cover exposing the last screw in the middle.
    • Remove the screw and save the plastic cover to put back on later when done.
  2. Dell Inspiron 11-3164 Screen Replacement: 2 단계, 이미지 1/1
    • Remove this one screw with the JIS #1 screwdriver in order to take of the holding plate for the wifi card adapter. Then remove the adapter.
    • Unscrew these two screws with a JIS#1 screwdriver.
    • Peel back the two metal brackets to remove the screen.
결론
Michael Kendziora
회원 가입일: 02/14/18
781 평판
안내서 5개 작성하였습니다
USF Tampa, Team S6-G4, Eyestone Spring 2018 USF Tampa, Team S6-G4, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 176
