주요 콘텐츠로 건너뛰기
Dell Inspiron 11-3164 Speaker Assembly Replacement
필요한 것
  1. Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: 1 단계, 이미지 1/2 Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: 1 단계, 이미지 2/2
    • Remove the eight 6mm back panel screws with your PH1 Phillips head screw driver bit.
    • Use your screw driver to remove the plastic cover in the center of the laptop.
    • Using a PH1 Phillips head screw driver bit remove the last 6mm screw.
  2. Dell Inspiron 11-3164 Speaker Assembly Replacement: 2 단계, 이미지 1/2 Dell Inspiron 11-3164 Speaker Assembly Replacement: 2 단계, 이미지 2/2
    • Use your metal pry tool to pry around the laptop until the two pieces separate.
    • There will be a ribbon cable holding the two pieces together, be careful not to rip it out of it's socket.
    • Use your metal pry tool to release the connector.
  3. Dell Inspiron 11-3164 Speaker Assembly Replacement: 3 단계, 이미지 1/2 Dell Inspiron 11-3164 Speaker Assembly Replacement: 3 단계, 이미지 2/2
    • Remove the speaker plug from it's socket.
    • Lift the speaker assembly from the case.
결론
Michael Kendziora
회원 가입일: 02/14/18
781 평판
안내서 5개 작성하였습니다
USF Tampa, Team S6-G4, Eyestone Spring 2018 USF Tampa, Team S6-G4, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 149
