소개
This guide will tell you how to replace your LCD screen. When working with screens, be careful about electrical discharges, and take steps to assure that the battery is disconnected for awhile before you follow this guide.
Tools
필요한 것
Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
Carefully flip the laptop over so that the top case is facing up.
Remove the top case of the laptop by gently prying along the seam with a plastic opening tool.
다른 한 분이 해당 안내서를 완성하였습니다.
