소개
If your laptop is still having issues and you've tried troubleshooting, you may need to replace your battery.
⚠︎ WARNING: Avoid contact with battery liquid, if the battery is leaking follow the battery manufacturer’s recommendations for cleanup and avoid contact with skin and eyes. If contact does occur, rinse gently with water and contact a doctor about the appropriate steps to follow. Dispose of used and no longer functional batteries responsibly. Check with your local authorities about ways to safely dispose of or recycle used batteries.
필요한 것
Flip the Chromebook to have the bottom facing you.
Make a note of all of the screws present. You may need to uncover some of them hidden beneath plastic tabs. The location of each screw is marked in the accompanying image.
이 단계에 사용된 도구:Tweezers$4.99
Before you completely pull off the back, you must disconnect the MB cord.
Using blunt-nosed tweezers, carefully flip the black bar that keeps the MB cord latched in as circled in the image.
Once open, grab the flat cord with your tweezers and pull horizontally until it comes free. Your bottom plate is now fully removed.
다른 한 분이 해당 안내서를 완성하였습니다.
