주요 콘텐츠로 건너뛰기
Dell Inspiron 11-3180 Bottom Case Replacement
필요한 것
  1. Dell Inspiron 11-3180 Bottom Case Replacement, Bottom Case: 1 단계, 이미지 1/1
    • Flip the Chromebook to have the bottom facing you.
    • Make a note of all of the screws present. You may need to uncover some of them hidden beneath plastic tabs. The location of each screw is marked in the accompanying image.
  2. Dell Inspiron 11-3180 Bottom Case Replacement: 2 단계, 이미지 1/1
    • Remove all nine of the 6 mm screws on the bottom with a size #00 Phillips screwdriver.
    • If needed, use a toothpick or the tip of your screwdriver to uncover the plastic that's hiding them.
  3. Dell Inspiron 11-3180 Bottom Case Replacement: 3 단계, 이미지 1/1
    • Flip the Chromebook upright and open it.
  4. Dell Inspiron 11-3180 Bottom Case Replacement: 4 단계, 이미지 1/1
    • Using the iFixit plastic opening tool, wedge it into the seam of the bottom plate. This will create a small gap between the sections that you can gently pry open. Work your way around to each side of the device until the bottom pops free.
    • Caution: DO NOT attempt to fully remove the bottom plate yet, as there are still connected wires. Doing so may result in damage to your device.
  5. Dell Inspiron 11-3180 Bottom Case Replacement: 5 단계, 이미지 1/1
    • Once you have pried enough space between the Chromebook and the bottom plate, flip it back over so the bottom plate is facing you and gently pull it up with your hands.
  6. Dell Inspiron 11-3180 Bottom Case Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Before you completely pull off the back, you must disconnect the MB cord.
    • Using blunt-nosed tweezers, carefully flip the black bar that keeps the MB cord latched in as circled in the image.
    • Once open, grab the flat cord with your tweezers and pull horizontally until it comes free. Your bottom plate is now fully removed.
  7. Dell Inspiron 11-3180 Bottom Case Replacement: 7 단계, 이미지 1/1
    • Finally, pull off the bottom plate carefully and set it to the side to continue with your needed repairs or replacements.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ivy Taylor
회원 가입일: 10/02/23
653 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 120
