소개
If you've tried the troubleshooting and your speakers still do not work, you may need to replace your speakers. This may be necessary if the speakers are old, or if they have been damaged. Speakers can be easily damaged if they come into contact with liquids. Be careful when replacing your own devices speaker, that you keep all parts away from harmful substances.
필요한 것
Flip the Chromebook to have the bottom facing you.
Make a note of all of the screws present. You may need to uncover some of them hidden beneath plastic tabs. The location of each screw is marked in the accompanying image.
Before you completely pull off the back, you must disconnect the MB cord.
Using blunt-nosed tweezers, carefully flip the black bar that keeps the MB cord latched in as circled in the image.
Once open, grab the flat cord with your tweezers and pull horizontally until it comes free. Your bottom plate is now fully removed.
다른 한 분이 해당 안내서를 완성하였습니다.
