주요 콘텐츠로 건너뛰기
Dell Inspiron 1100 CD Drive Replacement
필요한 것
  1. Dell Inspiron 1100 CD Drive Replacement, CD Drive: 1 단계, 이미지 1/2 Dell Inspiron 1100 CD Drive Replacement, CD Drive: 1 단계, 이미지 2/2
    • Unscrew the one 8mm Phillips #0 screw immediately below the RAM compartment and remove the panel.
    • This screw locks the CD Drive into place and must be completely removed before proceeding.
  2. Dell Inspiron 1100 CD Drive Replacement: 2 단계, 이미지 1/3 Dell Inspiron 1100 CD Drive Replacement: 2 단계, 이미지 2/3 Dell Inspiron 1100 CD Drive Replacement: 2 단계, 이미지 3/3
    • Unscrew the one Phillips #0 screw at the bottom of the RAM compartment cover, and remove the RAM compartment cover.
    • The screw does not separate from the cover. Be careful when using force to remove the cover. Also be sure that the screw has been completely unscrewed.
  3. Dell Inspiron 1100 CD Drive Replacement: 3 단계, 이미지 1/2 Dell Inspiron 1100 CD Drive Replacement: 3 단계, 이미지 2/2
    • Push and hold the switch inside the RAM compartment to the right.
    • This will cause the CD Drive to be slightly pushed out of its slot.
    • If the switch cannot be moved, check to make sure you have completed the first step in this guide.
  4. Dell Inspiron 1100 CD Drive Replacement: 4 단계, 이미지 1/2 Dell Inspiron 1100 CD Drive Replacement: 4 단계, 이미지 2/2
    • While holding down the switch in the RAM compartment, pull out the CD Drive.
결론
Alexander Pacheco
회원 가입일: 10/19/16
610 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 3-3, Isaacson Fall 2016 UMass Dartmouth, Team 3-3, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G3
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 366
