소개
In this guide, we will show you how to remove the Display Assembly.
부품
부품은 필요하지 않습니다.
  1. Follow the instructions in "Preparing to Work Inside the Computer." CAUTION: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of  your computer's electronic components. You can do so by touching an unpainted metal surface.
    • Follow the instructions in "Preparing to Work Inside the Computer."
    • CAUTION: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface.
    • Close the display.
    • From the back of the computer, remove the two M2.5 x 5-mm screws labeled "circle D."
  2. Open the display assembly approximately 180 degrees, and support the display assembly so that it does not open past this position.
    • Open the display assembly approximately 180 degrees, and support the display assembly so that it does not open past this position.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Remove the two M2.5 x 5-mm screws from each hinge bracket.
    • Remove the two M2.5 x 5-mm screws from each hinge bracket.
  5. Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
  6. Lift the display assembly up and out of the computer base.
    • Lift the display assembly up and out of the computer base.
결론
Terrence15
회원 가입일: 2017년 12월 18일
70,653 평판
안내서 442개 작성하였습니다
Informative Technologies Inc. Informative Technologies Inc. 회원
Community
15 회원들
안내서 925개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 2
전체 시간: 42
