주요 콘텐츠로 건너뛰기
Dell Inspiron 1100 RAM Replacement
필요한 것
  1. Dell Inspiron 1100 RAM Replacement, RAM: 1 단계, 이미지 1/3 Dell Inspiron 1100 RAM Replacement, RAM: 1 단계, 이미지 2/3 Dell Inspiron 1100 RAM Replacement, RAM: 1 단계, 이미지 3/3
    • Remove the one Phillips #0 screw at the bottom-center of the panel covering the RAM and remove the panel.
    • The screw does not separate from the cover. Be careful when using force to remove the cover as the screw may not be completely unscrewed.
  2. Dell Inspiron 1100 RAM Replacement: 2 단계, 이미지 1/2 Dell Inspiron 1100 RAM Replacement: 2 단계, 이미지 2/2
    • Use your hands to pull the two metal tabs away from the RAM.
    • The RAM will rise out when clear of the metal tabs. Do not force it into the up position.
  3. Dell Inspiron 1100 RAM Replacement: 3 단계, 이미지 1/2 Dell Inspiron 1100 RAM Replacement: 3 단계, 이미지 2/2
    • Pull out the RAM.
    • Be careful not to touch the metal contacts on the bottom of the RAM as this may damage it.
    • Store the RAM in an anti-static bag or a non-conductive surface, such as a stone or wooden table.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alexander Pacheco
회원 가입일: 10/19/16
610 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 3-3, Isaacson Fall 2016 UMass Dartmouth, Team 3-3, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G3
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 449
