소개
In this guide, we will show you how to remove and replace the Display Assembly.
필요한 것
Disconnect the Mini-Card antenna cables from the Mini-Card(s).
Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
Disconnect the display cable from the system board connector.
Remove the two screws (one on each side) that secure the display assembly to the computer base.
Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
Route the Mini-Card antenna cables through the routing guides on the computer base.
Connect the Mini-Card antenna cables to the Mini-Card(s).
