소개
If you are having difficulty with crackling, static, or a lack of audio on the Dell Inspiron 1150 laptop, this guide will be beneficial in demonstrating how to remove the speaker for replacement.
Before following this guide, you can try a few troubleshooting steps:
- Check for any debris that may be interfering with sound quality.
- Inspect the sound settings - reset and update, if applicable.
- Restart the laptop.
Be sure to disconnect the Dell Inspiron 1150 from all power sources and shutting it down completely before proceeding with this guide.
필요한 것
Place the laptop upside down on a clean, flat surface.
Locate the battery release button with the padlock symbol above it.
Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
Gently remove the battery from the side of the laptop.
Place laptop upside down on a clean flat surface.
Remove 2ea M2.5 x 5 mm screws.
Pull the HDD from main body of the laptop.
Place laptop upsid down on a clean flat work surface.
Remove the Philips M2.5 x 8 mm screw
Loosen the screw that holds the memory compartment closed
remove the memory module compartment cover
Press the Optical Drive release lever to the right and the optical drive should slide out of the case
Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
Lift the hinge cover off and set aside
Remove 1ea M2.5 x 8mm screw holding the EMI shield in place
Remove the EMI shield to expose the LCD ribbon cable
Gently pull up on the tab to disconnect the ribbon cable from the main board
Close the lid carefully and remove the two M2.5 x 5-mm screws from the rear of the case
Position the computer upside down.
Remove the twelve M2.5 x 8-mm screws.
Remove the M2.5 x 4-mm screw from the battery bay
The speakers are located along the front of the laptop
Disconnect the cables from the main board
Unclip the cables from the wire retainers
Pull straight up and out to remove the speakers
