소개
The hard drive is one of the most important components to any computer or laptop because without one, the laptop cannot turn on. Some times the hard drive may become full or corrupted, which may cause the device to slow down or become unresponsive. This guide teaches you how to replace it, and will utilize the steps from the keyboard replacement guide to do so.
필요한 것
Slide the latches outward to release the battery.
Pull the battery outward to remove.
Unscrew three black 1mm screws using the PH1 Phillips-head screwdriver on the bottom of the laptop around the battery.
The hard drive will be a silver rectangle. Slide the hard drive to the right to remove.
다른 2명이 해당 안내서를 완성하였습니다.
