주요 콘텐츠로 건너뛰기
Dell Inspiron 11z-1121 RAM Replacement
필요한 것
  1. Dell Inspiron 11z-1121 RAM Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 11z-1121 RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 RAM Replacement, RAM: 2 단계, 이미지 1/2 Dell Inspiron 11z-1121 RAM Replacement, RAM: 2 단계, 이미지 2/2
    • With a Phillips #1, loosen the 1 mm screw attaching the access door to the laptop body
    • Using your fingers, remove the access door to expose the memory card
  3. Dell Inspiron 11z-1121 RAM Replacement: 3 단계, 이미지 1/2 Dell Inspiron 11z-1121 RAM Replacement: 3 단계, 이미지 2/2
    • To access the memory card, push out the lashes on the left and the right of the memory card.
    • To remove the memory card, use your fingers to pull it out with the lashes still stretched out.
결론
Jerativat Satayarekha
회원 가입일: 10/04/16
123 평판
안내서 1개 작성함
USF Tampa, Team 1-5, Nance Fall 2016 USF Tampa, Team 1-5, Nance Fall 2016 회원
USFT-NANCE-F16S1G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 20
전체 시간: 475
