주요 콘텐츠로 건너뛰기
Dell Inspiron 1200 Display Assembly Replacement
필요한 것
  1. Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Ground Wire: 1 단계, 이미지 2개 중 1개 Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Ground Wire: 1 단계, 이미지 2개 중 2개
  2. Dell Inspiron 1200 Display Assembly Replacement, Remove the Screws: 2 단계, 이미지 1개 중 1개
    • Remove the four M2.5 x 5-mm screws (labeled "M2.5x5") that secure the EMI shield to the system board.
  3. Dell Inspiron 1200 Display Assembly Replacement, Releasing the Retention Tabs: 3 단계, 이미지 1개 중 1개
    • Pull the EMI shield out of the computer baseby rotating the front upwards then lifting to release the retention tabs from the retention-tab slots.
  4. Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Antenna Cable: 4 단계, 이미지 1개 중 1개
    • Disconnect the attached antenna cable from the Mini PCI card.
    • Close the display.
    • From the bottom of the computer, remove the two M2.5 x 5-mm screws labeled "D."
  5. Dell Inspiron 1200 Display Assembly Replacement, Remove the Screws: 6 단계, 이미지 1개 중 1개
    • From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  6. Dell Inspiron 1200 Display Assembly Replacement, Pull the Pull-Tab: 7 단계, 이미지 2개 중 1개 Dell Inspiron 1200 Display Assembly Replacement, Pull the Pull-Tab: 7 단계, 이미지 2개 중 2개
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
  7. Dell Inspiron 1200 Display Assembly Replacement, Removing the Cables: 8 단계, 이미지 1개 중 1개
    • Carefully remove the Mini PCI card antenna cable and the display cables from their routing guides.
  8. Dell Inspiron 1200 Display Assembly Replacement, Lifting the Display Assembly: 9 단계, 이미지 1개 중 1개
    • Lift the display assembly out of the computer base.
결론
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,858 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 315
