주요 콘텐츠로 건너뛰기
Dell Inspiron 13-5368 Heatsink Replacement
필요한 것
  1. Dell Inspiron 13-5368 Heatsink Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 13-5368 Heatsink Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Heatsink Replacement: 2 단계, 이미지 1/2 Dell Inspiron 13-5368 Heatsink Replacement: 2 단계, 이미지 2/2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Heatsink Replacement: 3 단계, 이미지 1/1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Heatsink Replacement: 4 단계, 이미지 1/1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Heatsink Replacement: 5 단계, 이미지 1/2 Dell Inspiron 13-5368 Heatsink Replacement: 5 단계, 이미지 2/2
    • Remove the battery.
  6. Dell Inspiron 13-5368 Heatsink Replacement, Heatsink: 6 단계, 이미지 1/2 Dell Inspiron 13-5368 Heatsink Replacement, Heatsink: 6 단계, 이미지 2/2
    • Unscrew the four screws securing the heatsink and remove it.
    • Remember to reapply a small amount of thermal paste, then screw the heatsink onto the motherboard in numberical order (i.e. 1, 2, 3, 4).
결론
Remember to clean off any old thermal paste, then apply a small amount of new thermal paste (dime size will be fine). Screw the heatsink on in numerical order so the thermal paste is evenly distributed on the processor. To reassemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Matt Sugrim
회원 가입일: 09/27/17
1,042 평판
안내서 6개 작성하였습니다
USF Tampa, Team S14-G6, Boczar Fall 2017 USF Tampa, Team S14-G6, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G6
4 회원들
안내서 13개 작성하였습니다
댓글 한 개
Is it normal for the heatsink to be loose right in front of the fan? The black part of the heatsink?
JRaje - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 15
전체 시간: 691
