주요 콘텐츠로 건너뛰기
Dell Inspiron 13-5368 Touchpad Replacement
필요한 것
  1. Dell Inspiron 13-5368 Touchpad Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 13-5368 Touchpad Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Touchpad Replacement: 2 단계, 이미지 1/2 Dell Inspiron 13-5368 Touchpad Replacement: 2 단계, 이미지 2/2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Touchpad Replacement: 3 단계, 이미지 1/1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Touchpad Replacement: 4 단계, 이미지 1/1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Touchpad Replacement: 5 단계, 이미지 1/2 Dell Inspiron 13-5368 Touchpad Replacement: 5 단계, 이미지 2/2
    • Remove the battery.
  6. Dell Inspiron 13-5368 Touchpad Replacement, Touchpad: 6 단계, 이미지 1/2 Dell Inspiron 13-5368 Touchpad Replacement, Touchpad: 6 단계, 이미지 2/2
    • Undo the clasps that hold the ribbon cables in place. Then, remove the ribbon cables.
  7. Dell Inspiron 13-5368 Touchpad Replacement: 7 단계, 이미지 1/1
    • Remove the 1.5mm Phillips #0 screws that hold the touchpad to the laptop case.
  8. Dell Inspiron 13-5368 Touchpad Replacement: 8 단계, 이미지 1/2 Dell Inspiron 13-5368 Touchpad Replacement: 8 단계, 이미지 2/2
    • Push up on the touchpad to release it from the housing. Then you can remove the touchpad.
결론
Matt Sugrim
회원 가입일: 09/27/17
1,042 평판
안내서 6개 작성하였습니다
USF Tampa, Team S14-G6, Boczar Fall 2017 USF Tampa, Team S14-G6, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G6
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 8
30일 전: 31
전체 시간: 3,346
