주요 콘텐츠로 건너뛰기
Dell Inspiron 13-5368 Webcam Replacement
필요한 것
  1. Dell Inspiron 13-5368 Webcam Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 13-5368 Webcam Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Webcam Replacement: 2 단계, 이미지 1/2 Dell Inspiron 13-5368 Webcam Replacement: 2 단계, 이미지 2/2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Webcam Replacement: 3 단계, 이미지 1/1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Webcam Replacement: 4 단계, 이미지 1/1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Webcam Replacement: 5 단계, 이미지 1/2 Dell Inspiron 13-5368 Webcam Replacement: 5 단계, 이미지 2/2
    • Remove the battery.
  6. Dell Inspiron 13-5368 Webcam Replacement, Screen Display: 6 단계, 이미지 1/3 Dell Inspiron 13-5368 Webcam Replacement, Screen Display: 6 단계, 이미지 2/3 Dell Inspiron 13-5368 Webcam Replacement, Screen Display: 6 단계, 이미지 3/3
    • Unscrew the 2mm screw that holds the WLAN card. Then carefully remove the WLAN card from the motherboard.
  7. Dell Inspiron 13-5368 Webcam Replacement: 7 단계, 이미지 1/1
    • Detach the black and white antenna cables from the WLAN card.
  8. Dell Inspiron 13-5368 Webcam Replacement: 8 단계, 이미지 1/1
    • Unplug the two display cables.
  9. Dell Inspiron 13-5368 Webcam Replacement: 9 단계, 이미지 1/1
    • Unscrew the screws that are securing the laptop's hinges.
  10. Dell Inspiron 13-5368 Webcam Replacement: 10 단계, 이미지 1/1
    • Detach the display from the base.
  11. Dell Inspiron 13-5368 Webcam Replacement, Webcam: 11 단계, 이미지 1/1
    • Use your plastic opening tool to pry the LCD back cover from the display panel.
  12. Dell Inspiron 13-5368 Webcam Replacement: 12 단계, 이미지 1/2 Dell Inspiron 13-5368 Webcam Replacement: 12 단계, 이미지 2/2
    • Carefully separate the back cover from the LCD screen.
    • Carefully remove the ribbon cable that holds the webcam to the screen, then unplug the webcam from the ribbon cable.
결론
Matt Sugrim
회원 가입일: 09/27/17
1,042 평판
안내서 6개 작성하였습니다
USF Tampa, Team S14-G6, Boczar Fall 2017 USF Tampa, Team S14-G6, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G6
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 17
전체 시간: 1,241
