주요 콘텐츠로 건너뛰기
Dell Inspiron 13-5368 Wifi Adapter Replacement
필요한 것
  1. Dell Inspiron 13-5368 Wifi Adapter Replacement, Wifi Adapter: 1 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the 9.6 mm screws securing the back plate of the laptop.
  2. Dell Inspiron 13-5368 Wifi Adapter Replacement: 2 단계, 이미지 1/1
    • Use a prying tool to remove the back plate.
  3. Dell Inspiron 13-5368 Wifi Adapter Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws holding the battery in place.
  4. Dell Inspiron 13-5368 Wifi Adapter Replacement: 4 단계, 이미지 1/1
    • Disconnect the cable connecting the battery to the motherboard, and then remove the battery
  5. Dell Inspiron 13-5368 Wifi Adapter Replacement: 5 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the 3mm screw and the metal bracket that holds the network adapter card in place.
  6. Dell Inspiron 13-5368 Wifi Adapter Replacement: 6 단계, 이미지 1/2 Dell Inspiron 13-5368 Wifi Adapter Replacement: 6 단계, 이미지 2/2
    • Pull out the network card.
    • To completely remove the network card, disconnect the two cords (white and black) from the adapter card. White on 1 and Black on 2.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Raj Dhavalikar
회원 가입일: 11/10/18
136 평판
안내서 1개 작성함
IUPUI, Team S4-G4, Wilson Fall 2018 IUPUI, Team S4-G4, Wilson Fall 2018 회원
IUPUI-WILSON-F18S4G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 32
전체 시간: 1,513
