주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7352 Cooling Fan Replacement
필요한 것
  1. Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: 1 단계, 이미지 3/3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Cooling Fan Replacement: 2 단계, 이미지 1/2 Dell Inspiron 13-7352 Cooling Fan Replacement: 2 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Cooling Fan Replacement: 3 단계, 이미지 1/1
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Cooling Fan Replacement, Cooling Fan: 4 단계, 이미지 1/2 Dell Inspiron 13-7352 Cooling Fan Replacement, Cooling Fan: 4 단계, 이미지 2/2
    • Remove the cord that runs from system board to the I/O board.
  5. Dell Inspiron 13-7352 Cooling Fan Replacement: 5 단계, 이미지 1/2 Dell Inspiron 13-7352 Cooling Fan Replacement: 5 단계, 이미지 2/2
    • Remove the 3mm and 4mm screws holding down fan with the Phillips #0 head.
    • Disconnect the fan wire from the system board.
  6. Dell Inspiron 13-7352 Cooling Fan Replacement: 6 단계, 이미지 1/1
    • Lift the fan from the rest of the device by picking up a single side and separating it from device.
결론
Chris Monte
회원 가입일: 09/30/15
393 평판
안내서 2개 작성하였습니다
University of Tampa, Team 1-5, Whiteside Fall 2015 University of Tampa, Team 1-5, Whiteside Fall 2015 회원
UT-WHITESIDE-F15S1G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 2,199
