주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7352 DC POWER JACK HARNESS Replacement
필요한 것
  1. Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement, Back Panel Removal: 1 단계, 이미지 3개 중 1개 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement, Back Panel Removal: 1 단계, 이미지 3개 중 2개 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement, Back Panel Removal: 1 단계, 이미지 3개 중 3개
    • Before disassembling your laptop, be sure it is powered off.
    • Remove the ten 7.5mm screws that secure the back panel with the Phillips #0 head
    • Use the plastic opening tool to remove the back panel. Start at the back corner and work across. The front edge of the laptop panel hinges and pivots upward after the back edge and the side edges are separated from the casing.
  2. Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the one 4mm screw with the Phillips #0 head that hold down the battery.
    • Use the plastic opening tool to remove DC Power Jack harness connector from the motherboard.
    • Gently remove the DC power jack harness from the device and replace it with a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Anthony Burke
회원 가입일: 03/08/15
109 평판
안내서 1개를 작성함
1가이드 댓글
This is perfect, but I’m curious how others may have handled an issue where the screw hole for my 7359’s power jack disintegrated. Anyone have any idea on how to anchor a power jack without that screw hole? I tried Sugru to mold around it, but that didn’t work. Any other ideas would be welcome.
Harry Morgan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 995
