주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7352 Hinge Replacement
필요한 것
  1. Dell Inspiron 13-7352 Hinge Replacement, Battery: 1 단계, 이미지 3개 중 1개 Dell Inspiron 13-7352 Hinge Replacement, Battery: 1 단계, 이미지 3개 중 2개 Dell Inspiron 13-7352 Hinge Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Hinge Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 13-7352 Hinge Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Hinge Replacement: 3 단계, 이미지 1개 중 1개
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Hinge Replacement, Hinge: 4 단계, 이미지 3개 중 1개 Dell Inspiron 13-7352 Hinge Replacement, Hinge: 4 단계, 이미지 3개 중 2개 Dell Inspiron 13-7352 Hinge Replacement, Hinge: 4 단계, 이미지 3개 중 3개
    • Remove the three 8mm screws with the Phillips #0 head connected to each of the hinges.
    • Take out the antenna cables from the routing guide on the hinge cover by pulling them from their original position
  5. Dell Inspiron 13-7352 Hinge Replacement: 5 단계, 이미지 1개 중 1개
    • Lay the screen flat on a smooth flat surface to release the hinges.
  6. Dell Inspiron 13-7352 Hinge Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron 13-7352 Hinge Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron 13-7352 Hinge Replacement: 6 단계, 이미지 3개 중 3개
    • Use the plastic opening tool around the edges of the screen to separate the screen back from the display until the backing is loose enough to pull apart with your hands.
    • The second image should be the result of removing the back of the screen.
  7. Dell Inspiron 13-7352 Hinge Replacement: 7 단계, 이미지 2개 중 1개 Dell Inspiron 13-7352 Hinge Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the hinge or hinges that need to be replaced and remove the two, or four, 3mm screws with the Phillips #0 head.
    • Remove the single, (or both, depending on if you are replacing one or both hinges) 6mm screw(s) from the top of the hinge with the Phillips #0 head.
  8. Dell Inspiron 13-7352 Hinge Replacement: 8 단계, 이미지 1개 중 1개
    • Grasp the hinge from the edge as shown and separate the hinge from the display.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Mikinna Martin
회원 가입일: 09/25/15
461 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 25
전체 시간: 6,950
