주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 13-7352 Memory Module (RAM) Replacement
필요한 것
  1. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: 1 단계, 이미지 3개 중 1개 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: 1 단계, 이미지 3개 중 2개 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 13-7352 Memory Module (RAM) Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: 3 단계, 이미지 1개 중 1개
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): 4 단계, 이미지 3개 중 1개 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): 4 단계, 이미지 3개 중 2개 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): 4 단계, 이미지 3개 중 3개
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
  5. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Chase Sparkman
회원 가입일: 09/30/15
512 평판
안내서 2개를 작성함
4가이드 댓글
Hello is the procedure same for 7353 ? can the ram be upgraded to 16GB. it currently has 8GB
Ali M - 답글 공유
Hi! Same questions as Ali M: Is the procedure same for 7353 ? can the ram be upgraded to 16GB: It currently has 8GB and I'd like to upgrade it to 16 GB.
Roberto de Souza Santos - 답글 공유
Did anyone ever get an answer if it can take 16 GB of RAM?
Robert Iversen - 답글 공유
A 16GB RAM would work but it should be a single sodimm module like CT204864BF160B
Hochan Son - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 43
전체 시간: 3,625
