소개
This guide will show users through the steps required to replace the main system board.
필요한 것
Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
Use the plastic opening tool to pry up and loosen the back panel.
Remove the back panel.
4 단계 Memory Module (RAM)
주의: 4-5 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Locate your memory module (RAM).
Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
Remove cord that runs from system board to the I/O board.
Remove connecting wire that runs from fan to system board.
다른 2명이 해당 안내서를 완성하였습니다.
