주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7353 Heat Sink Replacement
필요한 것
  1. Dell Inspiron 13-7353 Heat Sink Replacement, Flip the Computer: 1 단계, 이미지 1개 중 1개
    • WARNING: Please read the safety information shipped with your computer and follow recommended steps before working inside your computer. When finished working inside your computer, follow the instructions included in the safety information.
    • Close the computer display and turn the computer over so that the base of the computer is facing up.
  2. Dell Inspiron 13-7353 Heat Sink Replacement, Secure the Base: 2 단계, 이미지 1개 중 1개
    • Remove the ten screws that secure the base cover to the base of the computer.
  3. Dell Inspiron 13-7353 Heat Sink Replacement, Pry the Base cover: 3 단계, 이미지 1개 중 1개
    • Using a plastic scribe (plastic opening tool), pry the base cover off of the base of the computer.
  4. Dell Inspiron 13-7353 Heat Sink Replacement, RAM: 4 단계, 이미지 2개 중 1개 Dell Inspiron 13-7353 Heat Sink Replacement, RAM: 4 단계, 이미지 2개 중 2개
    • Before opening your device, ensure that all data is backed up on a hard drive to prevent data loss.
    • Loosen and then unplug the hard drive cable.
  5. Dell Inspiron 13-7353 Heat Sink Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron 13-7353 Heat Sink Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the two M2 3mm screws attaching the battery using the Phillips #1 screwdriver.
    • Remove the battery.
  6. Dell Inspiron 13-7353 Heat Sink Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron 13-7353 Heat Sink Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron 13-7353 Heat Sink Replacement: 6 단계, 이미지 3개 중 3개
    • Pry open the two clips.
    • Gently lift the RAM stick and pull it out of the motherboard.
  7. Dell Inspiron 13-7353 Heat Sink Replacement, Fan: 7 단계, 이미지 3개 중 1개 Dell Inspiron 13-7353 Heat Sink Replacement, Fan: 7 단계, 이미지 3개 중 2개 Dell Inspiron 13-7353 Heat Sink Replacement, Fan: 7 단계, 이미지 3개 중 3개
    • Unplug the daughterboard cable in two places, then remove the daughterboard.
    • Unplug the fan cable.
  8. Dell Inspiron 13-7353 Heat Sink Replacement: 8 단계, 이미지 2개 중 1개 Dell Inspiron 13-7353 Heat Sink Replacement: 8 단계, 이미지 2개 중 2개
    • Remove two 3mm screws from the cooling fan using the Phillips #1 screwdriver.
    • Remove the cooling fan from the laptop.
  9. Dell Inspiron 13-7353 Heat Sink Replacement, Heat Sink: 9 단계, 이미지 3개 중 1개 Dell Inspiron 13-7353 Heat Sink Replacement, Heat Sink: 9 단계, 이미지 3개 중 2개 Dell Inspiron 13-7353 Heat Sink Replacement, Heat Sink: 9 단계, 이미지 3개 중 3개
    • Remove three 2mm screws from the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Stephany Marin Restrepo
회원 가입일: 03/19/18
613 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 11
전체 시간: 299
