주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7353 Motherboard Replacement
필요한 것
  1. Dell Inspiron 13-7353 Motherboard Replacement, Flip the Computer: 1 단계, 이미지 1/1
    • WARNING: Please read the safety information shipped with your computer and follow recommended steps before working inside your computer. When finished working inside your computer, follow the instructions included in the safety information.
    • Close the computer display and turn the computer over so that the base of the computer is facing up.
  2. Dell Inspiron 13-7353 Motherboard Replacement, Secure the Base: 2 단계, 이미지 1/1
    • Remove the ten screws that secure the base cover to the base of the computer.
  3. Dell Inspiron 13-7353 Motherboard Replacement, Pry the Base cover: 3 단계, 이미지 1/1
    • Using a plastic scribe (plastic opening tool), pry the base cover off of the base of the computer.
  4. Dell Inspiron 13-7353 Motherboard Replacement, RAM: 4 단계, 이미지 1/2 Dell Inspiron 13-7353 Motherboard Replacement, RAM: 4 단계, 이미지 2/2
    • Before opening your device, ensure that all data is backed up on a hard drive to prevent data loss.
    • Loosen and then unplug the hard drive cable.
  5. Dell Inspiron 13-7353 Motherboard Replacement: 5 단계, 이미지 1/2 Dell Inspiron 13-7353 Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the two M2 3mm screws attaching the battery using the Phillips #1 screwdriver.
    • Remove the battery.
  6. Dell Inspiron 13-7353 Motherboard Replacement: 6 단계, 이미지 1/3 Dell Inspiron 13-7353 Motherboard Replacement: 6 단계, 이미지 2/3 Dell Inspiron 13-7353 Motherboard Replacement: 6 단계, 이미지 3/3
    • Pry open the two clips.
    • Gently lift the RAM stick and pull it out of the motherboard.
  7. Dell Inspiron 13-7353 Motherboard Replacement, Fan: 7 단계, 이미지 1/3 Dell Inspiron 13-7353 Motherboard Replacement, Fan: 7 단계, 이미지 2/3 Dell Inspiron 13-7353 Motherboard Replacement, Fan: 7 단계, 이미지 3/3
    • Unplug the daughterboard cable in two places, then remove the daughterboard.
    • Unplug the fan cable.
  8. Dell Inspiron 13-7353 Motherboard Replacement: 8 단계, 이미지 1/2 Dell Inspiron 13-7353 Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove two 3mm screws from the cooling fan using the Phillips #1 screwdriver.
    • Remove the cooling fan from the laptop.
  9. Dell Inspiron 13-7353 Motherboard Replacement, Heat Sink: 9 단계, 이미지 1/3 Dell Inspiron 13-7353 Motherboard Replacement, Heat Sink: 9 단계, 이미지 2/3 Dell Inspiron 13-7353 Motherboard Replacement, Heat Sink: 9 단계, 이미지 3/3
    • Remove three 2mm screws from the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink.
  10. Dell Inspiron 13-7353 Motherboard Replacement, Motherboard: 10 단계, 이미지 1/3 Dell Inspiron 13-7353 Motherboard Replacement, Motherboard: 10 단계, 이미지 2/3 Dell Inspiron 13-7353 Motherboard Replacement, Motherboard: 10 단계, 이미지 3/3
    • Remove 2 M2 3mm bracket screws, using the Phillips 1 screwdriver, on the LCD cable bracket.
    • Remove the bracket on the LCD cable.
  11. Dell Inspiron 13-7353 Motherboard Replacement: 11 단계, 이미지 1/3 Dell Inspiron 13-7353 Motherboard Replacement: 11 단계, 이미지 2/3 Dell Inspiron 13-7353 Motherboard Replacement: 11 단계, 이미지 3/3
    • Remove the plug of the LCD cable.
    • Remove the plug of the touchscreen cable.
  12. Dell Inspiron 13-7353 Motherboard Replacement: 12 단계, 이미지 1/3 Dell Inspiron 13-7353 Motherboard Replacement: 12 단계, 이미지 2/3 Dell Inspiron 13-7353 Motherboard Replacement: 12 단계, 이미지 3/3
    • Remove the plug of the DC Jack cable.
    • Remove the plug of the speaker cable.
  13. Dell Inspiron 13-7353 Motherboard Replacement: 13 단계, 이미지 1/2 Dell Inspiron 13-7353 Motherboard Replacement: 13 단계, 이미지 2/2
    • Be gentle and slow when loosening the keyboard cable tape.
    • Loosen the top of the keyboard tape.
    • Loosen the latches of the keyboard cable with a screwdriver.
    • Remove the plug of the keyboard cable.
  14. Dell Inspiron 13-7353 Motherboard Replacement: 14 단계, 이미지 1/3 Dell Inspiron 13-7353 Motherboard Replacement: 14 단계, 이미지 2/3 Dell Inspiron 13-7353 Motherboard Replacement: 14 단계, 이미지 3/3
    • Remove the plug of the touchpad cable.
    • Remove the plug of the keyboard backlight cable.
  15. Dell Inspiron 13-7353 Motherboard Replacement: 15 단계, 이미지 1/2 Dell Inspiron 13-7353 Motherboard Replacement: 15 단계, 이미지 2/2
    • Remove one M2 2mm wafer screw, using the Phillips 1 screwdriver, from the motherboard.
    • Remove the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Stephany Marin Restrepo
회원 가입일: 03/19/18
613 평판
안내서 5개 작성하였습니다
University of Memphis, Team S2-G2, Kim Spring 2018 University of Memphis, Team S2-G2, Kim Spring 2018 회원
UM-KIM-S18S2G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 966
