이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the 10 - M2.5 x 8mm screws located on the bottom of the device.
Detach and remove the Bottom Base Cover using an opening tool to pry it off.
Unplug and gently pull the hard drive cable to loosen it.
Remove the 2 - M2 x 3mm screws.
Remove the Battery.
Remove the 1 - M2 x 3mm and 1 - M2 x 2mm Wafer screw.
Remove the Cooling Fan.
Open the screen.
Loosen the LCD cable and peel it off of the base (highlighted with arrow).
Remove the 3 - M2.5 x 8mm hinge screws.
Loosen the keyboard cable tape.
Loosen the keyboard cable latches.
Unplug the keyboard cable.
Remove the 1 - M2 x 2mm Wafer screw.
Remove the Motherboard.
The piece remaining is the Palmrest Keyboard.
Unscrew the 4 - 2x2mm wafer screws.
Peel back any tape holding the back plate on.
Lift and remove back plate.
Peel back under-button tape.
Remove touchpad.
You have now stripped the keyboard! It is ready to be replaced.
다른 5명이 해당 안내서를 완성하였습니다.
