주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7359 Cooling Fan Replacement
필요한 것
  1. Dell Inspiron 13-7359 Cooling Fan Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Flip your device over so the back cover is facing you.
    • Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
  2. Dell Inspiron 13-7359 Cooling Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
  3. Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: 3 단계, 이미지 2개 중 1개 Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: 3 단계, 이미지 2개 중 2개
    • Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
  4. Dell Inspiron 13-7359 Cooling Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Hold the cooling fan with one hand.
    • With the other hand, grab hold of the part of the copper heat sink that is attached to the cooling fan.
    • Carefully pull the cooling fan away from the attached part so that it becomes fully disconnected.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Valentin Medina
회원 가입일: 01/30/18
703 평판
안내서 3개를 작성함
Baylor, Team S1-G6, Johnson Spring 2018 Baylor, Team S1-G6, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G6
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 19
전체 시간: 700
