주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7359 Speaker Replacement
필요한 것
  1. Dell Inspiron 13-7359 Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Speaker Replacement: 3 단계, 이미지 3개 중 1개 Dell Inspiron 13-7359 Speaker Replacement: 3 단계, 이미지 3개 중 2개 Dell Inspiron 13-7359 Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Speaker Replacement: 4 단계, 이미지 3개 중 1개 Dell Inspiron 13-7359 Speaker Replacement: 4 단계, 이미지 3개 중 2개 Dell Inspiron 13-7359 Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 Speaker Replacement, Speaker: 5 단계, 이미지 2개 중 1개 Dell Inspiron 13-7359 Speaker Replacement, Speaker: 5 단계, 이미지 2개 중 2개
    • Following the removal of the Battery, remove the left speaker.
    • As you lift the left speaker, carefully lift the wire that connects the left and right speakers.
  6. Dell Inspiron 13-7359 Speaker Replacement: 6 단계, 이미지 2개 중 1개 Dell Inspiron 13-7359 Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the small wires attached to the top of the right side speaker as marked in the photo.
  7. Dell Inspiron 13-7359 Speaker Replacement: 7 단계, 이미지 2개 중 1개 Dell Inspiron 13-7359 Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Use the plastic spudger to safely and easily detach the right speaker from the device.
    • Lift the right speaker out to complete the removal.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Katie Ragsdale
회원 가입일: 01/30/18
198 평판
안내서 1개를 작성함
Baylor, Team S1-G6, Johnson Spring 2018 Baylor, Team S1-G6, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G6
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 22
전체 시간: 414
