주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7359 WLAN Adaptor Replacement
필요한 것
  1. Dell Inspiron 13-7359 WLAN Adaptor Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 WLAN Adaptor Replacement: 2 단계, 이미지 1개 중 1개
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 WLAN Adaptor Replacement: 3 단계, 이미지 3개 중 1개 Dell Inspiron 13-7359 WLAN Adaptor Replacement: 3 단계, 이미지 3개 중 2개 Dell Inspiron 13-7359 WLAN Adaptor Replacement: 3 단계, 이미지 3개 중 3개
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 WLAN Adaptor Replacement: 4 단계, 이미지 3개 중 1개 Dell Inspiron 13-7359 WLAN Adaptor Replacement: 4 단계, 이미지 3개 중 2개 Dell Inspiron 13-7359 WLAN Adaptor Replacement: 4 단계, 이미지 3개 중 3개
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 WLAN Adaptor Replacement, WLAN Adaptor: 5 단계, 이미지 1개 중 1개
    • Unhook both of the wires attached to the WLAN adaptor.
  6. Dell Inspiron 13-7359 WLAN Adaptor Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the 3.9mm Phillips screw using Phillips #0 screwdriver.
    • Once the screw is removed, one end of the WLAN adaptor will raise up.
  7. Dell Inspiron 13-7359 WLAN Adaptor Replacement: 7 단계, 이미지 1개 중 1개
    • Gently remove the WLAN adaptor.
결론
작성자
1다른 기여자 명과 함께
Bo Yi Lim
회원 가입일: 04/02/19
205 평판
안내서 2개를 작성함
IUPUI, Team S3-G4, Harley Spring 2019 IUPUI, Team S3-G4, Harley Spring 2019 회원
IUPUI-HARLEY-S19S3G4
3 회원들
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 171
