주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7370 Fan Replacement
필요한 것
  1. Dell Inspiron 13-7370 Fan Replacement, Fan: 1 단계, 이미지 1/3 Dell Inspiron 13-7370 Fan Replacement, Fan: 1 단계, 이미지 2/3 Dell Inspiron 13-7370 Fan Replacement, Fan: 1 단계, 이미지 3/3
    • Make sure the laptop is turned off and not connected to a charging cable.
    • Using a Phillips #0 screwdriver, remove the ten (10) 2.5 mm screws fastening the bottom cover.
  2. Dell Inspiron 13-7370 Fan Replacement: 2 단계, 이미지 1/2 Dell Inspiron 13-7370 Fan Replacement: 2 단계, 이미지 2/2
    • Starting around the edges of the laptop, lift and remove the back cover. Apply pressure upwards, until you hear a popping noise.
    • Moving clockwise around the laptop, continue to apply pressure upwards, using your fingers or a plastic pick, until the bottom cover pops out of its locks.
  3. Dell Inspiron 13-7370 Fan Replacement: 3 단계, 이미지 1/2 Dell Inspiron 13-7370 Fan Replacement: 3 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the four 2 mm screws.
    • Carefully disconnect the battery from the motherboard.
  4. Dell Inspiron 13-7370 Fan Replacement: 4 단계, 이미지 1/2 Dell Inspiron 13-7370 Fan Replacement: 4 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the fan in place.
  5. Dell Inspiron 13-7370 Fan Replacement: 5 단계, 이미지 1/3 Dell Inspiron 13-7370 Fan Replacement: 5 단계, 이미지 2/3 Dell Inspiron 13-7370 Fan Replacement: 5 단계, 이미지 3/3
    • Lifting the fan, disconnect it from the laptop by grasping the connector (circled in red), and pulling out horizontally.
    • Do NOT pull the connecter upwards, as this may damage the socket you are pulling it out of.
  6. Dell Inspiron 13-7370 Fan Replacement: 6 단계, 이미지 1/1
    • Remove the fan from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zayed Azam
회원 가입일: 05/16/21
133 평판
안내서 1개 작성함
York University, Team S1-G6, Melo-Thaiss Summer 2021 York University, Team S1-G6, Melo-Thaiss Summer 2021 회원
YORK-MELO-THAISS-SU21S1G6
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 724
