주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7373 Battery Replacement
필요한 것
  1. Dell Inspiron 13-7373 Battery Replacement, Back Cover: 1 단계, 이미지 1/3 Dell Inspiron 13-7373 Battery Replacement, Back Cover: 1 단계, 이미지 2/3 Dell Inspiron 13-7373 Battery Replacement, Back Cover: 1 단계, 이미지 3/3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Battery Replacement, Battery: 2 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
    After this your MUST carefully unweave very thin black and red wires woven up and down at bottom of battery before the next step!
    Deborah Weaver - 답글
  3. Dell Inspiron 13-7373 Battery Replacement: 3 단계, 이미지 1/2 Dell Inspiron 13-7373 Battery Replacement: 3 단계, 이미지 2/2
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Battery Replacement: 4 단계, 이미지 1/2 Dell Inspiron 13-7373 Battery Replacement: 4 단계, 이미지 2/2
    • Remove the battery from the laptop.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 11명이 해당 안내서를 완성하였습니다.
John Egan
회원 가입일: 10/25/19
449 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G4
3 회원들
안내서 5개 작성하였습니다
댓글 6개
can you recommend a battery model #? I want to be certain I buy the correct one.
Peter Zinsli - 답글
The first step needs to be amended. There are 10 back cover screws including the central one, not 9. Additionally, the battery cable removes outward from the battery, not upward.
Mike Vandenberg - 답글
Hi Mike,
Thanks for the feedback! I’ll make the corrections you suggested.
Arthur Shi -
I'm told that you should replace the connector cable that connects the battery to the motherboard whenever you replace the battery. However that cable doesn't come with the kit. How do I get that part?
Bill Knapp - 답글
I found that I had to remove the back of the laptop from the touchpad side of laptop first, not the hinge side first as indicated in the pictures.
Rich Hunt - 답글
can you elaborate on that? I can't find any more thorough instruction on removing the backside after the screws have been removed.
Boheme Nellis -
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 45
30일 전: 144
전체 시간: 15,688
