주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7373 Daughterboard Replacement
필요한 것
  1. Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: 1 단계, 이미지 1/3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: 1 단계, 이미지 2/3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: 1 단계, 이미지 3/3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Daughterboard Replacement, Network Card: 2 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  3. Dell Inspiron 13-7373 Daughterboard Replacement, Daughterboard: 3 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  4. Dell Inspiron 13-7373 Daughterboard Replacement: 4 단계, 이미지 1/1
    • Remove the daughterboard.
결론
Kristen Gismondi
회원 가입일: 11/12/14
81,764 평판
안내서 200개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 297
