주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7373 Fan Replacement
필요한 것
  1. Dell Inspiron 13-7373 Fan Replacement, Back Cover: 1 단계, 이미지 1/3 Dell Inspiron 13-7373 Fan Replacement, Back Cover: 1 단계, 이미지 2/3 Dell Inspiron 13-7373 Fan Replacement, Back Cover: 1 단계, 이미지 3/3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Fan Replacement, Fan: 2 단계, 이미지 1/1
    • Remove the two screws holding the cover for the fan.
  3. Dell Inspiron 13-7373 Fan Replacement: 3 단계, 이미지 1/1
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
결론
To reassemble your device with the new fan, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Kameron Jusseaume
회원 가입일: 10/25/19
465 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G4
3 회원들
안내서 5개 작성하였습니다
댓글 2개
This was most helpful. We have a Dell 7373 model and the fan is quite noisy. We are going to disassemble and clean/replace it. Your tutorial explained it all. Thank you.
martyfukui - 답글
these 7373 seem to have a fan issue- I do IT for a business that has like 10 of them and at least 2 developed the same issue after a couple years- ordered new fans off of Amazon (tons of them and all look same except some have a flange on the bottom?) and no way to differentiate quality- both redeveloped the problem soon after installing fan- both were clean inside w no obvious issue- guessing the thin case has possibly bent down a tad and puts pressure on it- might take apart and see if I can bend part of case out a bit?) geez dell.
Garry Masters - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,171
